I have a 2012 Dodge Caravan Crew with 78k on it. I plan on replacing the plugs soon. Should I also replace the coils at the same time? Any info would be appreciated.
My opinion and my experience say no. I'm on my 4th. Chrysler minivan [all older models] and the plugs have lasted well over 100,000 miles. Had a mechanic recommend my son change plugs and a few coils on his Cadillac CTS. I changed only the plugs and all the problems went away.
But you should use iridium plugs since transverse V6's can be hard to work on getting to the back of the engine. And if you have to remove the intake, you might as well replace the valve cover gaskets while you're in there.
Easy enough to replace when they give you issues. My company truck. 223,000 miles, original plugs and coils as far as I know. Company only fixes stuff when it stops. 2005 Ford F150.
Still have the original coils in my Rav and Corolla (RIP). Coils are expensive; they're like $50 each in my engines. Unless your engine is known to eat coils, no reason to change them as part of PM.
