Hello all. Looking for a paint friendly solvent to remove the double sided adhesive that held my window covers in place on my truck. I've tried WD-40 and pb blaster to loosen it up before I carefully took a razor blade to remove most of it. I then put on straight ammonia and let it soak as I know it is good at loosening up window film adhesive, however this did not work for me. I've heard of using Goof Off, but that seems too aggressive to me, but I may consider it. Any suggestions would be very helpful.
