Where to buy rear end for 2500 Suburban 3.73?
Northern Virginia
Where to buy rear axle differential assembly for 06 Suburban 2500 3.73?
There is an Ebay entry for just under $1000, surely there has to be something cheaper? $400 or so?
REAR AXLE DIFFERENTIAL ASSEMBLY 00 01 04 05 06 Suburban 2500 3.73 Ratio Locker
You need to know if you have a 9.5" Semi-Float axle or a 10.5" Full-Float axle.
A good low mileage semi float 9.5" is worth $500 to $650, No interest in these from the hardcore 4x4 community.
A good low mileage full float 10.5" is worth $800-$1000, TONS of interest it these axles.
It this what you were looking at? http://www.ebay.com/itm/REAR-END-AXLE-DI...3ASuburban+2500
That is for a semi float......They're smoking Crack!!!!
