After a recent experience of using a much newer 690, I knew my 1995 model needed a bearing replacement.
The top, smaller bearing was easier to extract. It's a KYK 608Z made in Japan. Double shielded. It spun very easily, was noisy and play was evident. In my search I found that the double shielded version is listed as "608ZZ" while the single "Z" indicates a single shield.
The lower bearing was more difficult as I don't own an impact gun nor the appropriate socket. Instead I followed some instructions to make two arced wedges from a 2x4, slide them inside the aluminum housing, then tighten securely in a vise, thus locking the rotor. It did work...eventually.
The bottom, larger bearing is marked:
NTN 6202 LH on the face
NTN 6202 C3 Made in Canada on the circumference!
It has a blue rubber seal on both sides. It turns smooth, with little noise, doesn't sound "dry & raspy" as the top does. However, I can feel play in it and fell vibration when spinning the outside while holding onto the inside. So it's also Tango Uniform.
I was digging around in NTN's on-line catalog last night, at Amazon, Grainger, and some bearing/tool sites shopping around. I'll make a few calls locally tomorrow. Might get lucky.
I want to replace with a quality bearing given the application, RPM, lateral load, heat generation, etc.
Anyone hear replaced their router bearings?
