As has been pointed out, I have a web page on the subject:
Barry's Tire Tech - Load Tables
One of the things you should get out of that page is that the maximum tire pressure is relatively arbitrary and referencing that for usage pressure is not a good idea.
Some background for reference: In Aug of 2000, there was a massive recall of Firestone tires. At the time, it was pointed out that many vehicle manufacturers were not doing a good job of sizing their tires - that some vehicles needed either more inflation pressure or a larger tire. As a result every vehicle manufacturer made changes to the way they did tire size/inflation pressure - and this was completed by the 2008 model year. So some time between the 2001 model year and the 2008 model year, there was a change.
Prior to that, I was of the opinion that tire pressures should be run 3 to 5 psi HIGHER than the vehicle tire placard. I no longer hold that position.
As has also been pointed out, tire wear is not STRONGLY related to inflation pressure. There are other factors that play a larger role.
SO ....... I recommend people follow the vehicle tire placard for pressure if they are using the tire size listed there. If they are not using that size, then it has to be recalculated using the placard as a starting point.
This applies to summer tires, all season tires, and winter tires.
There is no great harm done by anticipating the drop in inflation pressure during the winter months and using up to 5 psi more than the placard. In other words, set your pressures up to 5 psi more while the weather is still warm, and you be good to 50 degrees colder than that - then adjust when it gets warm again.
