I did another oil change today. Took a TG off and put another TG on. The last 5-6 oil changes I've done, the filter gasket sticks to the housing and separates from the filter. The new filter gasket also had to be pressed back into the groove after taking it from the box. Frams are the only filter where the gaskets don't seem to be glued in place. Does anyone else have this issue with frams? Why don't they put a small amount of glue to hold the gasket in place? Never have this with motorcraft or napa filters. This happens to both the FU and TG. I always double check because of this but I'm dreading the day I forget and double gasket it. Still going to use the TG and FU for most of my changes with a MC or napa gold once in a while. I always lube the gasket with new oil before putting it on.
