Originally Posted By: Garak
Originally Posted By: oil_film_movies
Higher HTHS results in lower MPG, period, for these HTHS=3.0 5w30 engines getting HTHS=3.5 0w40, losing power and fuel economy due to higher viscous friction. Depends on your experiment style, as in how well independent variables are controlled. Its almost impossible to see the 1%-2% diff in MPG unless you do a true lab test.
This exactly. Look at what I run in my G37. I cannot tell the difference in fuel economy, simply because there are too many other variables. It's certainly there, if you could test for it carefully enough. An ordinary person outside a lab simply cannot do it.
Agree with ^^^^ however, I am taking the computer's word for the 1 MPG decrease measured over several years--driving mostly the same roads thru 4 seasons.
Hot idle OP increased from from about 24 to about 40
