Is there a comparable oil available that is the same as Caterpillar's T0-2. I believe this oil is an AW30 but with ? additives. This oil is obsolete to the new T0-4 fluid, which I can't see taking out a second mortgage just to fill a '87 D4H Cat dozer's transmission with. Also, the T0-4 is not recommended in the older machines.
