Originally Posted By: theKman
Originally Posted By: 05LGTLtd
Either of these options. The PGL is $16 at napa, but you will most likely have to order it.
I know it sounds odd, but I've actually purchased this at Walgreens, and a quick check of their website shows it in stock at the three nearest locations to me (and to the OP, for that matter).
Pretty sure LGTL referring to the PGL full strength(concentrate) which some Napas do stock. Walgreens and some other places stock and sell the 50/50 premix. The full strength makes doing a complete exchange after a system flush easier. Either one though would be a good option for the OP's vehicle.
Originally Posted By: 6starprez
Subaru Long Life Coolant or Subaru Super Coolant. Don't think it really matters. The super coolant is the blue fluid in late model Subaru's. The other one is green for older models prior to 2008 or 2009.
The older LL green comes as a concentrate but is a shorter service interval PHOAT, the newer 'Super' blue comes as a premix but is a longer service interval AF. They are compatible but to get the longer interval all the old would need to come out, and new in. Likely easiest way to go blue 'Super', is do some radiator d&f's on a shorter service interval. Gradually it will all be the blue Super.
And if one isn't concerned about matching AF color/tint, WM now sells Valvoline Asian Vehicle AF. Same as Zerex Asian Formula AF, but currently if ordered online for store pick up, ~$4/gal less than ZAF.
All that said, would keep in mind the head gasket check notations mentioned previously.
