AZjeff
$50 Site Donor 2023
I recently noticed the paint on the hood of my 2007 GMC has discolorization, from a side angle with certain lighting you can see uneven haziness with some spotting that looks like when oil is on water. I've been using clay bar and Collinite 845 for a few years but it's not enough obviously. The truck spends some time inside but mostly it's outside. I rubbed a small corner with some plastic polish and it seemed to remove the hazing but I don't know how it would be on the entire hood. What should I use to remove the haze and keep it off? The roof is probably the same but one thing at a time. I'm not comfortable with a buffer.
The paint isn't dull, I clayed and waxed the hood and the defects are still there.
thanks
thanks
