Hello all98 corolla VE 4 door model, 87,000 miles. Other night, i noticed my battery light came on then went away, few seconds later flashed on then dispappeared. did it again, but not at all last night. I noted thier was a pop noise, n slight squeel from serpintine wheel area. This was in the car driving. Checked battery voltage using an ohmeter on volts, its good, bought the battery last year. its showing 12.67 volts. I had replaced the belt, 3 years ago, an autozone one i think, and has about 30,000 miles on it. Still the original factory alternator, that is working just fine.
What gives? im thinking its just the belt needs too be replaced.
