I just recently added a Citroen 2CV to my collection of oddball European cars. Well when I mean "oddball", I mean odd for the United States. My Trabant would be recognized in Germany and former Eastern Bloc countries and the 2CV in France and other countries. My Yugo is recognized by people my age who were of driving age back in the 1980s but rarely by people as young as 25.
It uses a brake fluid called LHM. I was aware that Citroens were unusual cars and for some reason knew years before I even owned a Citroen they used special fluids so it was no surprise when I noticed it had green brake fluid.
It's supposed to be a type of mineral oil.
Prior to 1982, the Citroen 2CV had four wheel drum brakes and used DOT 3 brake fluid. In 1982 they went to front discs and this LHM brake fluid. The brake fluid and the reservoir cap are green indicating not to use DOT 3 brake fluid. I read in a shop manual in a pinch you could actually use something like baby oil if you could not find LHM fluid but to have the brake system flushed when possible but would not cause any ill effects to the seals in the meantime. However if you add DOT 3 or DOT 4, it will ruin the brake seals.
Since none of the auto part stores even sell GL-4 80/90 EP transmission oil, I didn't even bother to ask them if they carried LHM brake fluid (or course they would tell me they had never even heard of it) so I ordered it from a parts supplier here in the US. At least I didn't have to have one bottle shipped all the way from Europe!
Wikipedia lists the difference between brake fluids and seems like LHM is better than DOT 3 or 4. It's got a higher boiling point and I think does not absorb water like glycol based brake fluids.
https://en.wikipedia.org/wiki/Brake_fluid
Are the brake seals in the 2CV made of natural rubber or something? Why is DOT3 bad for this type of braking system?
Are there any other companies that use this same brake fluid? it would be great if LHM could be used to replace DOT 3 because I think I read it does not absorb water like DOT 3.
Years ago I had my eye on a sweet late 80s/early 90s Saab 900 convertible parked in front of some business with a for sale sign on it at a good price. Then some guy told me to stay away from it because Jiffy Lube topped off the reservoir with DOT 3 and it destroyed the brakes. Maybe Saabs used LHM fluid?
Speaking of Citroen 2CV brakes. This car has the best brakes I've ever seen! They are mounted on the transmission instead of at the wheels between the transmission and axles. I don't know if this provides better braking or the calipers have two pistons and the discs are bigger or what.
My Fiat Spider has four wheel power disc brakes and the Citroen puts it to shame when it comes to braking. The Fiat Spider, the braking power is so [censored] poor, you can't lock the brakes up at all. Well not on dry pavement anyway. That was Fiat's version of anti-lock braking!
