Originally Posted By: otis24
For every 10 degree drop in outside temperature, you lose one pound of tire pressure. I've heard it stated that filling the tires with nitrogen will negate that.
The 1 psi per 10 degrees F is a pretty good approximation. Pure nitrogen, the 93% or so stuff used to fill tires, or the 78% nitrogen/21% oxygen we breathe in the atmosphere all behave the same ... P1V1/T1=P2V2/T2, the "ideal" gas law simplification applies to most gasses.
Whether or not "nitrogen" inflation has ANY advantage with automobile use is addressed often in many groups. I believe I'm part of the vast informed majority who feel that almost all of its supposed advantage is that it tends to be dry.
