There is probably no benefit unless you are running a highly tuned motor. Even then, it takes tests and measurements to ultimately determine what size, and even if, a spacer is advisable. Some spacers were installed at the factory to act as a heat barrier to keep the carb cooler, but basically it doesn't work, so they quit adding them.
