Here's the exact quote and how it's written in the sales ad:
"Specially Designed for Use with FULL SYNTHETIC Motor Oil !"
So if a guy was to try to run dino oil in his engine with a NAPA Platinum oil filter, what would happen ?
What they state:
"Specifically Designed for Use with FULL SYNTHETIC Motor Oil !"
What they really mean:
"Specifically Designed for the intent and predication of MARKETING Premium Products that will go under-utilized regardless of which oil may be used, but are intended to catch the eye of the FULL SYNTHETIC Motor Oil waster !"
What would happen if you ran dino in such a filter? The same thing that would happen to any lube in just about any other filter; the particulate would be captured based upon the ISO beta efficency of any particular product you select.
The inference has been mentioned previously; these type filters are a good match for syn lubes that are used in L-O-N-G OCIs. They have a higher holding capacity for containment, and therefore support longer duration of use. However, if you don't subscribe to the really long OCI practice, they are a complete and total waste of money (that goes for both the lube and the filter). If you do not put yourself in a position to glean the true advantage, then the "benefit" is only perceived and not realized.
