Changing oil and oil filter in a Mercedes is very easy if you have the right tools, you don't need to raise the front to drain the oil, with a fluid extractor you can siphon used oil from the engine via dipstick tube.
With correct end-cap wrench you can remove the oil filter holder on top of the engine to change the cartridge oil filter.
Changing oil and filter in a Mercedes with right tools can be done in less than 30 minutes with dress cloth.
