Quote:
AC Delco lists efficiency of
98% at 25-30 microns. STP filters advertise 96% efficiency. I am assuming at 25 microns....
I'd like to see a published citing on those specs. Afaik, those specs are not listed on the box, nor have I seen them published. I do see that spec listed on Amazon, BUT, it says based on "
single-pass filtering efficiency". Single pass efficiency is not the ISO 4548-12 multi-pass industry standard. And based previous old single pass testing, they tend to 'look' better than multi pass testing. So I consider that to be a bogus and unreliable spec with a large fudge factor built in. In any case, single pass testing is not the industry standard for an apples to apples comparison.
As far as "assuming" what the micron level of the STP, why would 25um be the assumption? Why not 30 or 40 um. And if that assumption is based on a single pass testing that would be as unreliable as the AC Delco spec listed. As ACDelco is oem, those spec's are generally kept proprietary. The only ACDelco I've seen shown tested using ISO 4548-12 testing is the PF48 tested by Amsoil and I'm thinking that was/is classic construction, not ecore. It showed the PF48 to be ~95%@20um for that specific application. Note it's not some vague range like 20-30 microns.
I'm smiling that some of same folks critical of Purolator tears, would use a filter that has exhibited blown out media through the open nylon cage as shown in the link below. A tear in a metal centertube filter doesn't send media through the engine. And many/most ecore use a nitrile 'combo valve' combining the bypass and adbv in one function that is strickly done as cost saving feature over the traditional separate adbv and metal bypass used on the majority of oil filters. At least on GM application though, the bypass function is in the engine block, not so for other ecore applications though.
So, if one going to use an ecore, making an informed decision should include viewing the results of two Bitog members linked below. Caveat Emptor.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1806202&page=all
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1872312
