Wish I would have saw this earlier and I could have steered you clear. I work on outdoor power equipment out of my home shop as a side business to earn a little extra money. Vertical engines/pumps such that you just bought, realistically only last about 50-75 hours (or less) before the pumps die. Even the cheapest horizontal engine/pump would last 10 times longer and be a much better buy.
I actually recommend the 6.5HP Harbor Freight unit for those on a budget that sells for $349.99. Use the 25% off coupon available in many magazines and the price drops to $262.50. The engine is a Honda clone engine and nothing really goes wrong with them. Usually the only repair needed is a carburetor if the engine sits too long, and the carburetors are available for the ridiculous price brand new of $15/shipped.
http://www.harborfreight.com/2500-psi-3-gpm-65-hp-212cc-pressure-washer-69734.html#.UxND3IVgHO8
Or the 4HP with Honda GX120 clone engine is available for $195 after coupon.
http://www.harborfreight.com/4-hp-2000-psi-gas-pressure-washer-with-wheels-98444.html#.UxNHAoVgHO8
The pump on the Harbor Freight unit is a direct copy of a CAT triplex pump and is really good. If it should ever burn out, you can replace it with an actual CAT, AR, General, or Comet name brand pump for under $150. Pumps are only bolted on with 4 bolts and it is super easy to change a bad pump.
