I have a great 97' Previa LE SC van which is going to need a transmission fluid change out shortly. The Toyota dealer says they don't drop the pan and thus do not change out the filter, which by the way they say it's only a "mesh filter?" They use power flush machine. A local independent shop says there is a filter in there and will drop the pan and change out the filter . I need to know IF there is a replaceable filter in there, which method is preferred? Also, will special only Toyota fluid be the best. (If it is. I'll go and buy from dealer what's needed.) Thanks for any and all replies. Bill
