Originally Posted By: Trav
Thank you sir, but I don't want to pull the injectors at this time. I just wan't to
disconnect the electrical connector from the fuel injector - how do I do this?
Use a small flat blade screwdriver to pop the metal clip on the sides of the connector, it will pop out on one side then move to the other.
Install the metal clip on the connector first then just push it on till it clicks to reinstall.
No need to fiddle trying to install the clips with the connector on the injector, that would be a nightmare.
Easier yet, just squeeze it. I use my thumb on the curved wire section and my index finger on the back of the plastic connecter. Squeeze and pull. To reinstall, just push back on until you hear a click.
Edit: I need to learn how to type faster. cmorr and paulo beat me to it.
