Hi all,
I'm looking at flushing my coolant, and figured that on an 18-year-old car (1995 Oldsmobile Cutlass Ciera, 3.1L engine) that hasn't had *that* much attention to the coolant system, it may be a good idea to also run a bottle of cleaner (this stuff here: http://www.oreillyauto.com/site/c/detail/PRS0/AS1016A/N0453.oap)
When I drain the radiator, it's just the radiator that drains. There still seems to be quite a bit in the engine and heater core. On a ~11.5 quart system, I can get 4-5 quarts out of the radiator, plus another quart or so in the reservoir. The rest seems to be somewhere else in the system and won't drain out without a fight.
I'm planning on running a hose through the system to flush it out, but living in an apartment and not even owning a garden hose, let alone having access to a spigot, makes it a bit more of a pain. If I can, I'd like to drain the radiator and reservoir, dump the cleaner in, then fill the radiator and reservoir back up with distilled water for the 3-6 hours of driving to let it run through the system. Then I'll find a place where I can run a garden hose to do a total flush. Is that even how the cleaner is supposed to work? I'm not sure if the cleaner needs the entire system completely in water, or just more watered down coolant. Simply water kind of scares me, but I guess smaller trips not in winter can't be too bad.
Anybody have experience with the stuff? How do you use it?
Thanks!
-Brian
Thanks!
-Brian
