Originally Posted By: azsynthetic
Originally Posted By: dnewton3
I would ditch the syns and run a few inexpensive OCI dino flushes, and set a base-line. Then once established, one could experiment with the syn alternatives.
The 7.3L PSD oil change is 15qts each time so there is really no inexpensive flushes. Also, the OP is running an OCI that is 2 to 3x the factory recommend OCI so all bets should be off or at the minimum parlay.
Inexpensive is a relative term. Contrasted to synthetics, dino is less cost. Does not matter if it's 5 quarts or 55 gallons. The cost ratio is still the same.
As for the OCIs, this most recent one is only 5k miles, and yet the Cu and Pb are high on a "per mile" basis.
The Pb, while not directly harmfull, it getting high enough for condemnation, even at 5k miles in this last UOA. No number is an absolute in condemnation; they need to be judged in context. Unless we saw stupid-high numbers (which we don't in this case), he could run a bit further, but not much.
He's well versed in UOAs; he can make his own decision.
The Service Pro products have given him excellent UOAs in other equipment; why not try that? And IIRC, he get's it in bulk as well.
