Toyota Tundra 75W85 Gear Oil....
Georgia
My 2011 Toyota Tundra calls for 75W85 gear oil for the rear differential. This weight is pretty hard to come by...can I use a good full synthetic 75W90? If so, is Mobil 1 a good choice?
I plan on changing the rear gear oil early because I want to squeeze as many mpg's as possible out of my truck given these high gas prices. I have heard a good quality full syntheic gear oil may help some, as well as offer really good protection long term.
Any feedback would be greatly appreciated. Thanks...
I also have a 2011 Crewmax. Redline makes a 75W-85 synthetic gear oil. I have chosen to use Amsoil SVG 75W-90 in mine, though, mainly because I have used it in other vehicles with good results. I suspect 90% of people will just use 75W-90.
^^Go with this one. It`s the only brand of gear oil I`ll ever use.
Thanks very much for your feedback. So, it sounds like I can use 75W-90 without concern/issue.
I have heard great things about Amsoil SG. I was also looking at maybe using LubroMoly 75W-90. I can buy it locally (Napa) for $13.50 per quart. Lots of good options out there...
I thought the RL 75w85 was a transmission fluid???
How's thicker oil going to give you better gas mileage?
I assumed the 90 weight would shear over time to about 85. I figured the fully synthetic oil might help my mileage. I'm assuming the factory fill is Dino oil.
You are assuming a lot. Go with the Amsoil 75w-90, or the Reline 75W-85 GL5 - whichever you feel better about and can obtain at a reasonable price. Just my opinion, both are high quality synthetics. I haven't changed mine yet.
For the transfer case I am considering Redline MT-90, 75W-90 GL4.
You can get more info on each of their websites.
does the 11 have a mechanical LSD? my 06 needed an extra dose of the LSD additive on top of what's already in the amsoil lube.
I have seen improved mpg in every vehicle with synthetics in the driveline.... except maybe for the tundra. I went to amsoil in the trans and the axle and there may have been a .5 mpg improvement, maybe. during warm weather with no a/c I can just touch 18mpg in an easy, 45mph commute that's a good mix between hwy and city, so some stops, some stretches, 15 miles.
M
You are really assuming a lot. It is likely the rear diff is factory filled with 75W85 and very likely to be synthetic to begin with. 75W85 in a diff will give slightly better mileage at the cost of high temperature wear protection.
Synthetic oil is a good choice in a diff, but why do you think synthetic gives better mileage than a mineral oil of identical viscosity? The mileage advantage is usually from synthetics of equal high temp viscosity having lower viscosity at low temps.
Charlie
Don't know about the Tundra but I was shocked at how metallic dusted the diff oil in my FJ Cruiser looked at 5,000 miles. Very glad I changed it. I used Mobil 1 75w-90 as it was all that was readily available. I briefly contemplated filtering out all the metallic/particulate stuff in the original oil and putting it back in...but didn't have time.
