The stock horn in the Cruze, while sounding pleasant, does not cut through traffic. It's a single horn. I'm upgrading to dual horns (electric stock replacements, not air), and am wondering if those horns would be appreciably louder if a proper relay drawing power from a underhood power point was used. I'd probably use 16 gauge wire since it's pretty easy to work with, and I have a lot of smaller-gauge wiring supplies laying around from building my headlight harness a year ago. Should I go through the trouble, or just run both horns off the stock wiring?
