Thought I'd give this a whirl (no pun intended). My house has these cheap no-name, non-tilt windows with spiral rods on the sides for counterbalance to hold up the window. They often fail by making a racket when you open the window and the spiral rod hangs down. I have looked on the internet and don't find the instructions to be helpful.
What I need to know is:
- How do you know if the spiral balance mechanism is broken?
- The grease on them seems sticky. Is that the way they are supposed to be or should I clean and regrease?
-Can I replace them with some better design and how would I go about figuring where to get the parts?
- If I take the spiral rod out of the sash, are there parts still in there that need to be removed? I assume there is no way to remove the sash and I must find a way to fix the counterbalance or replace the whole window.
