Originally Posted By: GearheadTool
Originally Posted By: Volvohead
Originally Posted By: ueberooo
(I believe the volvo rec'd interval is something like 105k or 120k, . . .
It's 105k on the '00s.
The reason these cars wind up on lots for $2k in this mileage range is that the original owners dump them close to major maintenance time. Meanwhile, the maintenance doesn't get done. Along the way, the service book sometimes disappears -- then you're blind. If you can locate the original selling dealer (Carfax), they will sometimes still have the service history on their computer.
Sometimes, they go through a couple interim owners before they either die an early death (like a lot of other $2k corner lot specials) from missed maintenance and abuse, or someone who knows what they need invests the necessary money to keep them right.
Once maintained, unless otherwise abused, you can expect another relatively peaceful 100k+ until the next interval. And so on, and so on. The body structural and core mechanicals on them are like the Rock of Gibraltar.
This one has all the classic symptoms of that type of car: sludge (from 5w-30 dealer dino bulk changes at 7,500), a typical bad ABS (which the dealer likely quoted $600-800 to replace), and an overdue timing belt service ($1k at the dealer, $750-900 elsewhere). With no service records, you must assume that it was not done (unless the mechanic was thoughtful enough to paste a sticker on the belt cover). It wouldn't surprise me if the AC evap is also shot (that's $1,500+ at the dealer). Those are just some of it. Worn engine mounts, loose stabilizer links, the list goes on. Even routine maintenance items are not cheap. A set of the right spark plugs is over $40. And it eats lots of $4 premium fuel on top of it.
Definitely not a budget ride. And this is an AWD version to boot.
As mentioned before, unless the seller has done the work, you need to set aside at least $1,500 on a $2k example to bring them back to norm. Usually more.
But I sense the OP is completely oblivious to or in denial of all of this, and is honeymooning over what grades of RL to pour in it. I also get the sense that this was a budget-stretch to begin with. That's not meant to be disrespectful. But it seems to be the reality. This was a $40k car when new. They cost $$ to keep.
There's really not much more to add at this point.
I'll just quietly follow the OP's threads now, and see where the story leads. Sometimes it's a happy ending, sometimes not. I do wish him all the best with it.
Excellent post
The OP needs to be following your advice on this and appears not to be. That's a recipe for disaster
Ahhh, ye of little faith...
The money is getting saved up...
Sam's will get to do the ABS.. I drove the car to day with NO sensors acting up.
Oil is topped off, with MMO in it
Seafoam in the tank, one only
This thing WILL get handled, and I REALLY appreciate the advice.
I can tell you I LOVE the car and this oil will probably get changed in a month or so.
Time to turn this unloaded car into a gem. No problem re-marrying it at $2000. And no, it wont be the engine! Though its weird the CEL/SES light came on, then off.. Yes, it will get there.
*EDIT: I was tasked with buying a luxiry vehicle with next to no money, and I came away with a good example with many original parts. We turned down Subarus (too small) and Jeeps. I succeeded. Went to Pepperell, MA (near MA/NH line) to get it, too. It has only acted up twice but its supposed to act up zero times, the "wont accelerate right" issue was the strangest.. But I want to thank Volvohead, eljefino, etc.. The car will get serviced.
No offence intended here, but why waste money on Seafoam and MMO when that money could be, and SHOULD be put toward doing the timing belt? No magic potion in the world is going to save your valvetrain if that puppy snaps.
