Originally Posted By: hockeyfan19
I have Cobb's SF intake installed. I also have an Agency Power cat-less downpipe and Invidia Q300 exhaust. Even though it wasn't really necessary, I've always changed my oil at 3000 miles. Although after much reading, I'm more comfortable taking it to 4000+. I've never ran Rotella, but have heard great things. Does it hold up well with hard driving? I tend to drive fairly hard, and enjoy the occasional track day.
With the catless downpipe (DP,) make sure to monitor boost levels and LOG, LOG, LOG! If you notice any boost exceeding 17 psig max, or it doesn't taper down to 14 psig near redline, then you need to reflash to the Low Waste Gate (LWG) map. Also keep an eye on knock (feedback knock and fine learning knock,) long-term fuel trims (A/F Learning 1 is what Cobb calls it,) and your dynamic advances. If you have any other questions, I'd be happy to elaborate.
If you have a laptop, then I'd highly recommend downloading Cobb's AccessTUNER Race. It allows you to log more parameters and at a higher resolution than the AP dongle.
I would not run Mobil 1 (M1 for short) in either the EJ257 nor your EJ255. I'd stay away from resource conserving oils altogether if I were you. It would be a (slightly) different story were you the type who babies his turbo Subie, driving mostly highway miles and never at WOT to redline. With track days in your future, however, something like T6 would fit the bill quite nicely.
As you can see in my signature, I'm running Amsoil SSO 0W-30 and it doesn't appear to be holding up much better than Rotella T6 did. I bought 10 qts of SSO off a member here on BITOG, so this next run will be my second and last. Since the last run was mostly over the looooong, cold winter, and this one was all through the summer, I'm hoping the used oil analysis (UOA) turns out better.
I planned to go with something more exotic than even Amsoil (Renewable Lubes,) but bought another 10 qts of Amsoil's Euro 5W-30 formula, so that will be my oil for the next year. If it doesn't show well, I may give up boutique oils altogether, stop sending off samples for analysis, and simply run Rotella T6 for 4-5k intervals, which is seems it can very easily do.
Originally Posted By: Xstang
If it's still under warranty, go with 5w-30 every 3750 miles.
If not, then a 40-grade every 4k should be fine.
OEM filters are fine-lots of paranoia when they first went to the "blue" filter (I remember a mega-thread on rs25.com about that), but so far I can't remember reading about a fatality related to them.
Royal Purple and Redline? Yes, if you enjoy spending money
If you read NASIOC at all, they will make you believe that Mobil 5w-30 will make your bearings go to pieces. What I remember myself after going to Rotella is that my valve-train became a LOT quieter.
For warranty purposes, SOA would have you believe that 2011+ turbos, while using synthetic, much change their oil at least every 7,500 miles or 7.5 months; however, I would not recommend this, even using something as stout as T6 until you confirm it with a UOA.
4-5k without an UOA should also be fine, but you can't go wrong with 3,750 miles if you take the car to the track or REALLY beat the heck out of 'er.
I personally use the OEM Blue Honeywell oil filers. Even at more than 7,500 miles, the cut-open filter looked great.
