I'm getting ready to buy another case of transmission fluid for my 2005 Accord with 192K miles. I usually do a drain and fill every 15K miles with ATF-Z1. I see that Honda is discontinuing Z1 and replacing it with DW1. Should I buy a case of DW1 or Z1? My gut tells me to just get the Z1 since it has worked fine for the last 192K miles and it still shifts like new.
My 2010 Acura TSX came with Z1, but I most likely will transition it over to DW1 since it is so new and the Z1 fluid will no longer be supported and will be increasingly hard to find.
