I have been experimenting with trying to replace VersaTrak fluid wherever I can on a 2005 Montana SV6 - it is now $32 per PINT. I have given up on the rear drive module(RDM). Nothing has been satisfactory except for VersaTrak fluid.
In the transfer case (TC), I decided to try Castrol HypoyC (6 ounces) with LubroMoly MoS2 engine supplement (1 ounce) -7 oz capacity. Since I had seen metalic particles at the initial TC drain, I decided to do a couple of flushes with the same concoction each about a month apart. Everything seemed fine. The drained fluid appeared very gray from the MoS2. On the last flush, I switched to straight RP SynchroMax that I had left over from experimenting with the RDM. I decided to flush the dregs of the old fluid from the bottom drain hole and the tube on the end of my syringe scraped the bottom of the TC. When I depressed the plunger, large "chuncks" flushed out. I recovered the chuncks and they were clearly MoS2 that had settled out from the previous runs of Hypoy C/LubriMolyMoS2. I supposed that since the gear oil doesn't have much in the way of dispersants or detergents, the colloidal MoS2 settle in my case may not represent engine oil.
There doesn't seem to be any harm done, but MoS2 was clearly settling out of the Hypoy C in a daily driven TC. I am convinced that opaque gray oil at drain CANNOT be used as evidence that MoS2 stays in suspension. My drains were gray AND MoS2 was settling out.
Just a warning...
Just a warning...
