Originally Posted By: rshunter
The ones you're wanting to avoid are called "worm gear" clamps. It sounds like you're describing "T-bolt clamps" as your item of choice. I was able to buy them in bags of 10, IIRC. Unfortunately, I can't recall where I bought them. At least knowing what they're called may help you find them...
P.S.: I know that you can get them at Fastenal, but there is probably a cheaper source nearby. I'd give Lowe's or Home Depot a try.
Well yes of course they are called worm gear hose clamps, but as you know there are cut variety that everyone sells and so called "Euro-Seal" "Breeze" variety that don't have cuts - the worm gear engages parallel indentations. All the hose companies for whatever reason are discontinuing Dixon "Euro-Seal" "Breeze" clamps in 21-38mm.
