Several years ago I was chasing down what ultimately was a failing ECM, and I removed the Air Charge temperature sensor on my throttle body injected LA 318 to test the Ohm readings at different temperatures.
I wound up removing the grease on the probe part, and later learned it was to help transfer heat.
Anyway, I'm getting a flat spot in the throttle only at a certain temperature while it is warming up and I think this lack of grease might be a possibility.
Anybody know what grease I should use to replace what I removed, and where I can get it?
