D daves66nova Joined Apr 11, 2004 Messages 4,005 Location los angeles Feb 21, 2011 #1 how can i hook up a tach that was used for a diesel to run on a gasoline engine?
E expat Joined May 12, 2009 Messages 5,532 Location Canada Feb 21, 2011 #2 Would the tach read high enough? What engines? Why not change the tach to one suitable for a gas engine?
D daves66nova Thread starter Joined Apr 11, 2004 Messages 4,005 Location los angeles Feb 21, 2011 #3 If i remember correctly,it reads to 4,000.I want to use it on a 4 cyl.I have this one already,don't want to buy another one if i can just rewire it
9 97prizm Joined May 25, 2005 Messages 4,954 Location USA Feb 21, 2011 #4 I briefly skimmed the following article and it looks like you might be able to perform the tach swap, but with some work involved. VW diesel Tach
K Kuato Joined Oct 23, 2005 Messages 7,998 Feb 21, 2011 #5 You'll be taching it up to redline all the time!
JHZR2 Staff member Joined Dec 14, 2002 Messages 52,841 Location New Jersey Feb 21, 2011 #6 My diesel tachs use a magnetic kick-up and an amplifier ha creates the pulses that drive the tach. How would your application pick up the signal?
E expat Joined May 12, 2009 Messages 5,532 Location Canada Feb 21, 2011 #7 If you are talking about your 22R, you may be able to pick up the signal from a terminal on the side of the coil/ignitor (used for the Gas tach)I'm not sure if the reading will be accurate (or, for that matter if it will work at all)
