Hello All,
Yesterday I did some experimenting with oil viscosities to see how it relates to oil temperature.
Testing was done on a Harbor Freight 3050W generator with a 6.5hp Chonda engine. All test were done at the same ambient temp (55F), and the generator loaded with two 1500W heaters.
It was running almost WOT until the oil temp had stabilized and not changed for 20 minutes before taking a reading.
I had an extra oil-fill cap for the engine, so I drilled a small hole in it and pushed a thermocouple type K through it and sealed with RTV.
All measurements are in Celsius, since that is all my indicator has.
The engine already had Mobil1 15W50 in it, so that was used for my initial test.
Test 1.
Mobil1 15W50
Runtime 30 minutes under full load. Oil temp stabilized after 10 minutes.
Measured oil temp was 96C
Test 2.
Rotella 30W
Same time conditions as test 1.
Measured temp was 94C
Test 3.
Royal Purple 10w30
Test 4.
Rotella 15W40
Measured temp was 95C
Conclusion is that my normal fill of Mobil1 15W40 is running slightly higher in cold weather.
In the summer we often have 100F+ temperatures, so I opt to keep using 15W40 or 15W50 for this unit.
The generator was clearly making less mechanical noise with the 15W50 oil.
The generator was running ALMOST WOT on all tests, and I did not detect any difference in RPM (3600rpm +- 20rpm) or throttle position between the oils.
Older Honda specs for this engine is:
10W30 from -5F to 90F
10W40 from -5F to 110F+
20W50 from -15F to 110F+
Any comments would be appreciated.
Test 1.
Mobil1 15W50
Test 2.
Rotella 30W
Test 3.
Royal Purple 10w30
Test 4.
Rotella 15W40
