Well, I put a new thermostat in my Moms Olds 88 last summer, easy as pie. It has the o-ring seal instead of a gasket, which most cars now have. Every repair manual for every car I've seen with this design never says anything about using RTV around the housing, so I never have. Well, recently, my moms car has been losing coolent, so we had it pressure tested and it was leaking through the thermostat housing. ***? I made sure the o-ring was evenly placed around the edge of the stat etc.; **** , I even used my freakin torque wrench to the speced torque for the bolts on the housing. Do any of you guys use RTV on the o-ring type seals? I know your supposed to with a traditional gasket. I used a stant thermostat and seal. Maybe it was just a crappy one? The dealer installed a new thermostat and OEM seal. Stuff like this just pisses me off because I'm super anal retentive when working on everything, especially cars, and when stuff like this happens, it puts a dent in my ego I guess
