IF you understand the symptoms of lean/rich starting mixtures, and adjust your automatic choke properly.... or have a manual choke..... the carbureted cars started as fast as a modern fuel injected car. Maintaining that perfect tune probably eluded most mechanics and customers... but if you were your own mechanic you soon got it perfect!!
Actually my carbureted cars started better than any fuel injected car I have ever had, for one simple reason:
You could precharge the intake manifold with gas fumes by pumping the gas pedal the correct number of times - it varied with every car you owned. (The accelerator pump in the carb squirts in a thimble full of gas each time you do this)Then the car would start on the first cylinder up, probably a 1/4 second turn of the key would make it start every time, even well below zero.
Flat spots and over choking still were issues, all through warmup, unless you had a manual choke. Never really figured out why anybody thought the automatic choke was worth it.
Many of my cars had manual chokes - 41 plymouth, 59 ford, 59 Opel, 64 Fiat, 67 BMW. The Fiat used a Weber carburetor with an enrichment valve instead of a choke, this was every bit as good as fuel injection except..... the carburetor cost more than the short block if you were buying!! Ouch!
No, I would not go back!!
