I saw this document today from ZF about ATF's for buses: http://www01apps.zf.com/kst464/ZF_InteroeleV2_manager/Work/2010-01-01/TE-ML 14_es0701.pdf
In it, they divide the ATF's in four quality levels (page 2): 14A for 30.000 Km /1 year oil change interval, 14B for 60.000 km / 2 years OCI, 14C for 120.000 Km / 2 years OCI, and 14D for 150.000 Km / 3 years OCI.
It kept my attention the fact that all the oils of group 14C (except KOMPRESSOL, I think) were from the BP group (Castrol, BP...) (pag. 8).
I compared the technical characteristics of some of them and this is what I found:
Note that the european Castrol Transmax Z and the BP Autran LTF are almost identical except for a slightly variation in the 15ºC density. The rest are very similar.
It surprised me the differences between the australian and european Transmax Z and specially between the UK and Brazil Castrol Transynd, also between Allison and Castrol Transynd (I think it's the same product). Also, the Brazil and Allison transynd are Dexron III certified, but UK on is not.
In fact, they are all Dexron III certified except european Transmax Z, BP Autran LTF and UK transynd. They share most of the rest of the certification from MB, ZF, Voith...
What do you think? It seems like they are all the same product with slightly variations due to measurements conditions, isn't it?
Would you use one of those three that are not Dexron III certified in a transmission requiring Dexron III?.
