Originally Posted By: VeeDubb
I'm surprised the TSI only took 4.4 qts. My FSI manual says it takes 4.4 too, but 5 qts gets it exactly at the top of the hash mark on the dipstick.
Yeah, I love my Passat too. Have owned it now going on 3 years and still get excited to drive it on a long trip. I've driven rentals of the new Malibu, Camry and Altima, and they just aren't the same, at least not the 4 cylinder versions.
I poured in 4 quarts, started up the car and let it run for about 3 minutes. Turned it off and topped it off with 0.4 more quarts. About an hour later, had to run into town for errands. After about 20 miles and upon getting home, I checked the level again and it was topped off.
Originally Posted By: Vizzy
OP....
DO NOT CHANGE THE FACTORY FILL OIL TOO EARLY!!!!!!!!!!!
The fact is VWoA won't definitely state what is contained in the FF and it may well still have break in properties that the typical consumer is unaware of!
If you must wait until around 4 or 5k and then change it.
Make sure to use the VW specified approved oil for your engine. Not doing so may void your warranty.
If you use the dealer ask them to see the bill for the bulk fill they are receiving....Be polite but insistant on this. If they are honest they won't hesitate to show you the bill.
It used to be common for US VW dealers to actually use DINO fill for all service..and it ruined quite a few engines!
Well versed on VW and their requirements.......
Factory fill is long gone (already in the Checkers recycle barrel) after 1,000 miles and GC is doing its job. GC is a 502 oil, so no worries.
Don't really care if VW poured in some vooodooo breakin stuff, I have seen enough FF UOA's with 1,000 miles on the oil....and plenty too much iron and copper....and I am dumping that junk. As for VW and their recommendations....I think they are full of [censored]. Before they gave away three free oil changes, their first service was at 5k. Then all the sudden the oil changes were free and the 5k Service disappeared and became 10k. They are friggin nuts. First of all, I am not doing 10k OCI's. I will do 5k OCI's on this 2.0T motor, period....end of story. There is no question that good 502 will have a powerful TBN to make 10k miles, but this engine will quickly shear even the greatest oils a full grade and the TBN will still be in the 4's to 5's. For me it will be 5k.
Don't care if I wasted good oil or money. Makes me feel better.
