You can see how much wear improved with the oil change. Aluminum still has room for
improvement but with another oil change or two all wear should read normally. The viscosity of the oil was a
bit low for a 5W/40 and read in the 5W/30 range. Regardless of its cause, we don't think the low viscosity is a problem and no harmful
contaminants were found. The TBN read 4.8 so you still had plenty of active additive left. Try going
11,000-12,000 miles on the next oil.
MI/HR on Oil 10,500
MI/HR on Unit 14,450
Oil Rotella Synthetic 5w-40
ALUMINUM 13
CHROMIUM 1
IRON 29
COPPER 27
LEAD 2
TIN 5
MOLYBDENUM 75
NICKEL 1
MANGANESE 3
SILVER 0
TITANIUM 0
POTASSIUM 4
BORON 20
SILICON 12
SODIUM 7
CALCIUM 2355
MAGNESIUM 217
PHOSPHORUS 958
ZINC 1170
BARIUM 3
SUS Viscosity @ 210°F 61.9
cSt Viscosity @ 100°C 10.75
Flashpoint in °F 385
Fuel % .05
Antifreeze % 0
Water % 0
Insolubles % .03
TBN 4.8
I had a punctured oil filter at 8500 miles, replaced the filter and 1 quart with Rotella Synthetic 5w-40.
MI/HR on Oil 10,500
ALUMINUM 13
CHROMIUM 1
IRON 29
COPPER 27
LEAD 2
TIN 5
MOLYBDENUM 75
NICKEL 1
MANGANESE 3
SILVER 0
TITANIUM 0
POTASSIUM 4
BORON 20
SILICON 12
SODIUM 7
CALCIUM 2355
MAGNESIUM 217
PHOSPHORUS 958
ZINC 1170
BARIUM 3
Fuel % .05
Antifreeze % 0
Water % 0
Insolubles % .03
TBN 4.8
