The post on 'Best home wire stripper' prompted me to investigate wire strippers further and I found that there is a difference between solid wire strippers and stranded wire strippers
http://www.kleintools.com/ToolCatalog/PDFs/04_Striprs_Cuttrs_Crimp.pdf
Klein has the 11045 stripper for solid wires and 11049 stripper for stranded wires. I wondered why notches in a wire stripper sized for a 14ga solid wire will not work for a 14ga stranded wire. I considered two possibilities. Perhaps stranded wires need slightly larger stripping notches since, being stranded, the diameter is slightly larger than the dia of solid wire. Or, perhaps, the stranded wire will deform slightly under the pressure from the stripper blades and the notches on a stranded wire stripper are slightly flattened (oval in shape)to account for the deformation.
But then there is the Klein 1011 which is rated for both solid and stranded wire. This seems to negate my two previous hypotheses. Now I am puzzled as to the difference between solid and stranded wire strippers.
