vehicle-----------------04 Toyota Tacoma, 2RZ-FE, 2.4L, 4 cyl
OIL---------------------5.8 qts 3:1 Amsoil ASL 5W-30/ASM 0w-20 incl 3 oz Auto-RX
oil additive------------3 oz Auto-RX
Make up oil-----------none
Engine oil capacity---5.8 quarts
oil filter----------------Amsoil EaO57
air filter-----------------Amsoil EaA
miles on oil/filter------12,175 (apprx 1 year, 9/08-9/09)
miles on vehicle--------63,456
UOA by Oil Analyzers:
Overall severity of report--------3 (abnormal)
LAB COMMENTS: Viscosity is SIGNIFICANTLY HIGH; Total Base Number is MODERATELY LOW; Infrared results indicate beginning lube oxidation; Boron is moderately low for this lubricant; Lubricant change acknowledged
WEAR METALS in PPM:
iron--------------------10
chromium-------------0
nickel------------------0
aluminum-------------2
copper-----------------7
lead--------------------6
tin----------------------0
cadmium--------------0
silver-------------------0
vanadium-------------0
CONTAMINANT METALS:
silicon-----------------22
sodium----------------9
potassium-------------2
MULTI-SOURCE METALS:
titanium---------------0
molybdenum---------46
Antimony-------------0
Manganese-----------0
Lithium---------------0
boron------------------63
ADDITIVE METALS:
magnesium-----------13
calcium----------------3612
barium-----------------2
phosphorus------------713
zinc---------------------938
Lube change-----------YES
Lube filter change----yes
fuel Soot Water visc40------------------n/a
visc100----------------15.3
TAN--------------------n/a
TBN--------------------3.36
oxidation--------------52
nitration---------------34
NOTES/COMMENTS:
This is my brother's truck. Probably around 60% highway, 40% city. Some towing apprx 1300# trailer. Viscosity of first UOA -- ASL without Auto-RX, 8,346 miles---slightly high at 11.3. So, it appears to me the very high viscosity is due to Auto-RX. Compared to last sample, which had about 1,000 more miles: iron is up 1 ppm; aluminum up 1 ppm; copper down 2 ppm; lead down 2 ppm; silicon up 2 ppm; sodium up 2 ppm; potassium up 1 ppm; viscosity up from 14.6 to 15.3. Sodium & potassium only showed up in UOA’s with Auto-RX use. TBN holding up well. Looks like air filter may need cleaning. Oil on dipstick looked fairly clean/clear. I’d expect viscosity to come down after next oil change, as present run without Auto-RX could be considered a highly modified rinse phase.
PREVIOUS ANALYSIS: http://www.bobistheoilguy.com/forums/ubb...true#Post945029
http://www.bobistheoilguy.com/forums/ubb...rue#Post1243473
OIL CHANGED TO: 1 qt Amsoil ASM 0W-20 & remaider Amsoil ASL 5W-30. NO Auto-RX added.
WEAR METALS in PPM:
CONTAMINANT METALS:
ADDITIVE METALS:
NOTES/COMMENTS:
