i guess a good thing to consider here is that, if there isn't anything stated in the box, then treat it as a pair. just be paranoid... its your life on the line here.
i have a 3 ton rated jack stand for garage diy use that has been rated per jack stand (3 tons per jack stand), but i still treat it as 1.5 tons per jack stand.
also, i don't really have the habit of bring up the whole car on at least 4 stands. what i do is raise only either the fron or the rear and if possible, i don't remove the wheels. i only remove the wheels if necessary.
