Whether its needed or not is irrelevant. I will always prefill my filters, even my upside filter. To avoid spillage on horizontal or upside filter locations, don't overfill it.
The media is a sponge and should have no problem soaking up 1/3-1/2 capacity. And, if you have a vertical no spill filter location, there is no reason not to fill it 3/4's or more.
This will also help you remember to lube the gasket which should prevent future removal issues. And, oiling the gasket might just remind you to recheck the filter mount or old filter to prevent the DIY common double gasket syndrome.
Since cold oil will cause the filter BPV to leak more, even though my bottled oil is unfiltered, I don't worry about the negatives of running new unfiltered oil through the engine, since your filling the filter through its output and not input.
I personally hate the start up rattle of a dry filter. That sound of death, even for only 3 seconds, is annoying.
