have new yamaha 25hp 2-stroke outboard, still less than 10 hours on it so been running premix at 25:1 with yamaha oil. Have about 5-6 hours on it currently. Been running great for first 3-4 hours, lots of power and hits top rpm. Tach reads 5800 rpm.
One time cruising around 4000 rpm had to avoid some junk in water so I rapidly closed the throttle. Ended up stalling motor, was very hard to restart, when running sounded funny at idle and wanted to stall unless I gave it throttle and ran > 3000 rpm. So i ran that way back to the dock for about 10 minnutes. Got back to dock and motor all better.
Ran fine for next week.
This past week been losing top rpm, dropped to 5200 wot at first now it won't get on plane and loses all power anything greater than 2000 rpm. If i pull the choke it roars briefly and I can feather the choke for about 2 seconds at most to get power.
Brand new gas tank and it's fresh gas. So i'm hoping it's a gummed up carb from all the oil, a stuck float maybe.
I've pulled the plugs and they look great, they are clean no deposits even. And the motor will idle and run < 2000 rpm fine, with expected amount of smoke.
Anybody with similar experience?
