Keeping this car and engine related.. and ENTERTAINING..
We have all seen people do crazy stuff, piston soaks, seafoams, modifications, snake oils etc.
What would you like to see that may or may not have been done already?
Here are 6 things that i would like (love) to see-
1) 20w50 in a Prius. What if anything will happen? MPG suffer? Engine run worse? No prius owner would ever do it... it would make them cringe.
2) 0w20 in a Harley. What if anything will happen? No Harley owner would ever do it...cringe.
3) Boroscope of combustion chamber that has only seen the cheapest gas no additives... versus a Boroscope of an engine that has only seen top tier and high dollar addtives. vs. Boroscope of an engine that has only seen E85
4) Valve cover removal of engine that has only seen quiky lube oil changes when the light comes on, versus valve cover removal of an engine that has only seen top tier synthetics and filters changed at less intervals.
5) A video of a red blooded BITOG that has only used the best oil and filters and top tier gas for the life of their vehicle... then running one interval of Supertech oil and filter along with the cheapest gas. Did he sleep at night? How was his anxiety? Did his engine make noises? Was it louder? How many MPG did he lose? How bad does he need a UOA to see the damage that was done? What will he do to fix the damage done by the cheap oil and cheap gas?
6) 0w20 in a diesel truck and towing.
Would you like to see any of these? What else would be entertaining??
