Your machine pics
NY Capital District
Well, prostreetcamaro reminded me of something. Sure we can hear what your PC is, but lets see. Cool case, or dell, or beige it don't matter.
Case: NZXT Alpha Black
CPU: Intel Core 2 Duo E7300 (@ 3.4Ghz/400Mhz FSB)
RAM: Patriot Memory PC2-6400 4GB (2x2)
HDD: WD 640GB SATA/16MB/7200
GPU: Powercolor Radeon 4670 512
Sound: Sound Blaster Audigy SE
PSU: Antec Neo Eco 400C (400W/80 plus silver)
Cooling: Arctic Cooling Freezer 7 Pro, Scythe 120MM 1200RPM, Silverstone blue LED 120MM 1200RPM, NZXT 120MM 1100RPM
It's not that bad. I clean it out every 6 months, I'm about 4 months out. There is no dust in the CPU heatsink or other heatsinks.
Pics of PC
Only thing I am not happy with is the non-modular power supply. (looks wise)
Will probably go modular soon, although the Seasonic power supply still rocks. Stable and reliable as can be.
Case: A+ El Diablo
Motherboard: Biostar A770 A2+
Memory: Rendition (Crucial) 4gb (4x1gb) DDR2 800
CPU: AMD Phenom 9600 2.3ghz quad core
GPU (video card): EVGA Nvidia GeForce 9500GT 512mb
HDD: Hitachi Deskstar 500gb 7200rpm SATA
Power supply: Rosewill Green Series RG-430 430 watt
Optical (cd drive): NEC 16x DVD+/-R IDE (took it from my old computer since it still works)
OS: Windows 7 Home Premium 64 bit
Sound: Turtle Beach Riviera pci
Cooling: CPU- included with processor. Case- Cooler Master 120mm for exhaust fan, case came with intake fan and side fan. Computer is actually very quiet, when I put it together I choose fans with low decibels.
Asus 23" LCD monitor
Antec P183 Case
Antec CP-850 PSU (specially for Antec's CPX line of cases)
Lite On DVD and CD-RW drive
640 GB WD Caviar HD. 7200rpm, 32mb Cache, SATA
AC Freezer 64 Pro Cooler (huge!)
Kingston HyperX 4 GB DDR3 1600
AMD Phenom II X4 955 Black Edition Deneb 3.2 Ghz (no OC yet)
ASUS M4A79XTD EVO
ASUS Geforce 9500GT GFX Card
Windows 7 Pro 64 bit
Pretty clean inside too :)
HTPC setup
Intel Core 2 Duo E6300
ASUS P5N-SLI Premium mobo w/ nvidia 590i chipset
1GB RAM
160GB HDD
DVD-ROM drive
Cardboard box case held together with hot glue
IR sensor for remote
nvidia 210 GFX card (built in HDMI and sound ftmfw)
HP 350w power supply
CPU and GPU is cooled by a single speed controlled fan
Components are secured using hot glue
Originally Posted By: rudolphna
Hey buffman isn't your cooler on backwards? It's s'pose to blow towards the exhaust fan in the back of the case
LOL I thought when I was reading the directions to have it point that way. That or I simply wasn't paying any attenion at all and mounted it backwards... CPU is at 39C right now. I'll have to get some down time to change it apround.
Heres my "HTPC." Well, its not done yet.
It used to be my old primary, then I got the one above for Christmas so it was retired and stripped of parts. I got it together again but I need a larger HD and a Tuner card. Probably get a Graphics card with Native HDMI sometime later as well.
BioStar P4M900-M4
Intel Pentium 4 "Prescott" HT 3.2GHz
Corsair DDR2-800 (@DDR2-667)
eVGA nVidia 9800GT 512MB
Creative SB Live! 24-bit
Seagate 7200.8 250GB
Pioneer PATA 8x DVD-[+](R)W
LiteOn PATA 52x32x52x CD-(R)W
PC Power & Cooling 420ATX
Windows Vista Ultimate (Yeah, I know, I had a legal key so its what it has. :P)
There is the only problem with this board. It has pretty bad NorthBridge cooling. Ive even added the 40mil fan and its not enough under heavy loading. It get hots enough to burn my finger. Ive opened the minidumps from the inevitable bluescreen and the failure is always with the graphics driver, so I suspect the heat is a causing a failure of the PCIe link. I have a larger cooler on the way and hope that will fix the issue..
It doesn't help that one of the hottest running CPUs ever is exhausting right onto the north bridge.. probably not that well thought out as far as design on Biostar's end, mainly only when using Pres"hott" CPUs though.
TDP of the Prescott is 90W, which was very high at the time; TDP of a AMD "Barton" was 72W. But any high-end CPU today has a TDP in the 130-140W range. It still wasnt well thought out, obviously. It needs active cooling or a large heatsink. More so since it has a graphics core built in. Would probably crash even faster with the IGP active.
My home machine is an Inspiron 510 (boring)
Here is my work Laptop. Panasonic CF-52 Semi-rugged. Magnesium case, 15 inch screen, 4 GB ram, 160 Sata 2 Travelstar HDD. Windows XP. It is in the docking station. Sprint 595 Air Card for when I am mobile.
One of our Motor Units Itronix Go Book MR-1 Laptops. These things are tiny, have crummy hard disks, fail frequently. the zip ties keep the battery from shifting and turning the unit off.
The Panasonic Toughbooks are the bomb. 3 foot drop rated. magnesium case. Not super fast, but [censored] reliable.
Yes, that is my business card. I am not hiding anything. Panasonic Lappys are the [censored]. U.S. based support in Leawood Kansas. Mil-spec rated. The CF-52 goes for about 1500 dollars, as spec'd. Mark III is coming out with touch screen and LED keyboard lighting. Mine is the MK II. I will be getting a MK III in about a month.
Dave
I'll play
Case: APEVIA X-JUPITER-JR G-Type
M/B: ASUS P5Q Pro
CPU: Intel Core 2 Duo E7400 stock (at the moment)
RAM: Patriot Extreme Performance 4GB (2x2GB) DDR2 1066
and OCZ Reaper HPC 4GB (2 x 2GB) DDR2 1066
HDD: Seagate Barracuda 7200.10 250GB 7200 RPM 16MB Cache
Storage HDD - Western Digital Caviar Green 1TB 32MB Cache
GPU: HIS H485QT512P Radeon HD 4850 512MB
PSU: SIGMA SHARK SP-635 635W
Cooling: XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
Wants: Bigger screen, faster OS/program drive($$SSD$$)
This is one of my older servers, I've not customized one like this in some time. The customers get nervous for some reason:
