You could have knocked me over with a feather....
S California
Have you ever met a real redneck mechanic? I just had the maintenance adventure of a lifetime. This guy bought an Audi A4 with a turbo 4-cylinder engine traded for an old motorcycle because the engine was completely sludged up and a mechanic quoted an outrageous price to swap in a junkyard engine, more than the car was worth to the owner. The dealer was worse, much worse, so it was adios amigo to the Audi for the owner.
The new owner, our redneck friend completely warmed up the engine and pulled into his driveway. He then poured a quart of laundry bleach into the running engine and ran it for about 15 minutes. Then with the engine still running he pulled the drain plug and as the oil drained he poured 5 gallons of used 15w40 diesel oil (he's a diesel mechanic) in the engine as it ran and oil drained out the bottom into a big pan. As the oil ran out he poured a gallon of new diesel oil in and as he started to run out of new oil he shut down then engine, changed the oil with new 15w40 diesel oil and a new filter.
His wife has been driving the car for about a thousand miles now with no problems and no sludge. To say I was surprised would be a bit of an understatement.
He said he's going to modify the pan so that it holds 6 quarts of oil and he says if he can get his hands on the jerk that designed all this he'd wring his neck. He said that getting in there to get the oil pan will be the worst headache he's ever had working on a car. The only reason he got the car and might keep it is because new new wife likes it and he bragged that he could "fix" it.
Does bleach dissolve sludge? not that I'm aware of. I'd be concerned the chemistry experiment would dislodge a big piece of thick sludge that might plug up something important...wait and see I guess.
I thought one way they destroyed engines was by bleach in one of the goverment auto revival programs? I could believe a detergent maybe but bleach?
We've got to find the name of the jerk that invented the setup so we can see him wring his neck and then wash up the bloody mess of blood with bleach afterwards.
It is pretty crazy, but it makes sense that the engine didn't seize as he didn't really run it without oil. I think engines will run for a little bit even without any oil and he just had it at idle instead of under load.
No it's some kind of chemical that turns to cement or something when it heats up.
I know a guy that uses that line and I wouldn't be the least bit surprised if he did that. He's a mechanic.
It's sodium silicate.
Doesn't sound like its the first time he's performed this magic,sSo I'm going to assume he has had some success with it in the past. He didn't read about it on an internet forum, or watch a youtube video. I doubt the engine is any worse off than it was before, and its still running, so why question the guy from behind your keyboard?
He told me he used this method before and it works. He would take an old truck or tractor that someone thru away and fix it up.
The bleach he used was a bit stronger than household bleach. It's stuff that's used by farmers and ranchers.
That's a load of nonsense. Either you or your "mechanic" have been sniffing too many bleach fumes.
Originally Posted By: OneEyeJack
He then poured a quart of laundry bleach...
So which was it? Laundry bleach or the mythical "stuff" that farmers and ranchers use?
Adding bleach to an engine will ruin it in short order. There is no "stuff" used by farmers and ranchers, unless you're talking about calcium peroxide. But calcium peroxide, as used in agriculture, is a solid and would be a bit difficult to pour into an engine.
If you've ever cleaned up engine sludge (I've done a number of old tractors) you'd realize that bleach does nothing to clean up sludge.
That makes sense. That's water glass and is used to apply stove gaskets and seal up wood stoves.
