Ok I am a member of another site and recently a few members were blaming synthetic atf for failures in 4L60e transmissions. I find it hard to believe. Someone mentioned that YANK who make high performance torque converters says you CANNOT run any synthetic atf period. I decided to email Yank to get an answer as to why. FWIW, Rossler performance transmissions and many others have ZERO issue with the use of a synthetic DEX III.
Yanks response- Synthetic based oils are designed to be slippery to reduce friction this is not what you want in a performance clutch application if you are to drive normal or like granny that use them!
But the clutch material used in production and the sprags that are in the converter and transmission have a surface designed for standard type fluids and do not hold well with slippery oils.
I find this statement to be a bit strange. I guess friction modifiers and other additives have no effect in formulating a synthetic atf!
Thoughts?
