- Joined
- Dec 7, 2012
- Messages
- 3,664
The power steering pump in the Suburban keeps groaning and is foaming its fluid. I'm inclined to think its on its way out. I recently changed a leaking PS pressure to Hydroboost line. FWIW this pump has been ran low a few times.
I'm a bit confused on what to buy. I only need the pump as I'll transfer the can and pulley. The truck is a Z71 truck and does have BPH RPO code, but does NOT have the Y91 Luxury Edition package RPO. I probably will buy the pump through NAPA.
Looking up on RockAuto, it seems like there's conflicting info. Excluding the Y91, or with Y91 or BPH...
Then AAP lists, one pump for either Y91 or BPH, or one Without Y91 or BPH.
Then NAPA lists one as with Y91 or without Y91. Technically I do NOT have Y91, but other resources are alluding to Y91/BPH calling for the same pump.
Anyone have any insight as to what pump I need?
