I recently bought a 1998 Mustang with the 3.8 v/6 engine. When I changed the oil, I put in 10w30 Delo, which is a diesel oil from a couple years ago that has higher levels of ZDDP. It just dawned on me that cars with catalytic converters shouldn't use high ZDDP oils. Does this engine even have flat tappets? It doesn't burn oil, so will the high ZDDP even be a problem for the cats? The car only has 79000 miles on it.
