No Intelligent Battery System means it doesn’t have a way to register the battery. The electronics needed to monitor the battery aren’t in the positive terminal so - nothing to talk to to register.
These R56 Minis use either a Group 47 or 48 battery (a 48 is a tight fit but can be done), and are old enough pre 2011 that they used flooded batteries. You can use an AGM if you wish. I used both in mine with no issue, no need for battery registration, no electrical faults. I have the Mini-specific scan tools to register the battery if needed, but it can’t be done on my non-IBS equipped Cooper S. I used these scan tools on BMWs that needed that registration back in the day, and they had huge positive battery terminals with the monitoring devices built in.
Unless the indys and that one dealer have the car in the bay and can see it for sure, they are guessing. If the terminal is plain, the battery that’s in it should be ok. I’ve run a battery for a while unregistered in a car that requires it and it never damaged the electrical system. But I didn’t run it for weeks either.
